Old Oct 21, 2023 | 08:31 PM
nickwe21's Avatar
nickwe21
Default Re: Front hood emblem?
Definitely to be found on EBay an they will ship to Kuwait as well. Way to replace it is to drill right into the middle of the emblem, then use a screw driver to peel off the whole emblem (in pieces). Remove the glue left behind with rubbing acohol or Goo-gone, clean the area with soap afterwards and then use some strong adhesive to glue it back in. 3M double sided tape doesn’t work well for some reason. I used some 3M decal silicone adhesive and works like a charm.
let me know if you can’t find it and I’ll find you one!
