Old Oct 30, 2023 | 10:57 AM
Isaacmaple08's Avatar
Isaacmaple08
Default Re: New member - both low beams not working
That looks like water leaking in through the firewall opening. You might want to make sure your drains under your wiper cowl are clear. Also check the date on the alarm siren while you're under there. Hopefully it's been replaced or removed.
You can search out the alarm troubles and water problems in the search bar.
Here's a video on how to remove the cowl:
https://www.youtube.com/watch?v=Zkyf...hannel=HammerD
I'll probably create a new thread with more of a build log I suppose, this thread isn't about low beams anymore. I did find some answers to the squirrlyness of some of my standing lights though, some liquid in the locking module. Wire brush + Sealed that area and replaced the 'foam' it looks like a repair was attempted before at some point. Also found a lot more rust in the front of the car while replacing the AMP. it took most of the day pulling carpet, hitting wit with a wirebrush and sealing it with POR15. I wasn't able to completeley get the rust or wire brush the front like I wanted due to seats and me being 6'3" but the idea is to do that this weekend and pull the center console, carpet, seats, etc. out and completely fix and seal the rust. I just wasn't ready for 40 degree temps in Texas overnight. Right now I just have a car cover. Still need to do this fix you suggested sir.
