Old Oct 31, 2023 | 06:50 PM
Bettyboo's Avatar
Bettyboo
Default Re: Buying a Crossfire - common technical issues/problems?
Originally Posted by XFiringInNC
I haven't seen a lot of horror stories about the mechanicals of the Crossfire here. There's a rear end bug that causes the rear end to make a whining noise but that is fixable under warranty and I haven't heard of anyone's rear end flying off or anything. It's a misalignment between the rear end and the drive shaft from the factory.
For the most part the engine is good, though go fast parts are hard to come by. So if speed is your main thing, get the SRT-6 as you won't find much to help you scratch that itch for the base/limited model and the SRT-6 comes from the factory with a supercharged 330 hp, stiffer suspension, etc. etc. I haven't read a lot of horror stories here about people having engine difficulty.
Check your seats if you're going to buy one to make sure both the back and butt warmers are working. That seems to be a common failure.
I've had mine for several months now and I'm quite happy with everything about it.
carparts.com will have almost any part for the crossfire
