Old Oct 31, 2023 | 09:49 PM
GraphiteGhost
Default Re: Break NIGHTMARE! (pedal squishy & traveling)
Originally Posted by mikemadeit94
I believe this is solved thank you everyone that put their thoughts together! The end of the day I had seized calipers in the rear that where shot, and the fronts where slightly seized I regreased and reinstalled and everything seems to be back to normal! Also believe I had a bad master cylinder but cannot confirm. After general maintenance bench bleeding the master etc everything seems to be back to normal.
Thank you for reporting back, many do not. Lets hope this takes care of your issue long term!
