pizzaguy
You are not telling us what you are doing. WHY are you looking at this? Did you change the module? Have you had issues of some sort, if so, what? What are you working on? NONE of us will recognize that ambiguous code, so try telling us the history here and perhaps we can put 2 and 2 together and give you an answer you can use.
Recently purchased the car, trying to find out which modules have a DTC and why, I've cleared and fixed most myself with replacing wiring and modules or Testing with DRB3 but not this. The amp area did have water in it and extensive Corrosion, the airbag light was previously on and then after changing the battery and replacing the stock infinity amp it is now off. I decided to use DRB to look at all the modules and these DTCs came up as active, that's my concern. I assumed the DRB code may be readily identifiable.
pizzaguy
You had to say it, so I had to respond, that's how the internet works:
Why? I've been in two collisions since 2014. I was injured lightly in both crashes. BOTH times, my injuries came from the airbag deployment, not the collision.
Do not confuse a liability-mandated device (an airbag) with an actual safety device (a seatbelt or crumple zone). My airbag module in the car is bad and out of service, the one in my pickup has been disabled.
When I die and my son sells the car, the service history booklet says, on page 1: "The airbag module is disabled, the warning light is disabled and the airbags will not activate." (The truck will be dead long before then......)
Cool flex I guess, I'm not interested in selling the car currently and may do that then. My daughter is 4, if it's all the same to you, I'd rather have a passenger airbag that works even if in the olden days they didn't have airbags and everyone turned out fine.
mikemadeit94
Strange you’re not getting an air bag light my assumption would be nothing is wrong if that light is not appearing and fuse 3 is good but I’m not sure? I’m dealing with the a similar issue issue and purchased a junk yard module and didn’t realize it’s not plug and play (apparently another member posted theirs worked like that) but if you get anywhere let me know. I’m waiting on a carsoft MB scanner to test my air bag faults.
From another few posts in the forum I was reading it said the airbag module had to be initialized with a DRB3/Emulator or Star tool, I assume that's probably the issue you're having if it's still not working. I'll have to check through history and see if I can find the thread that references it.
