Old Nov 7, 2023 | 10:14 PM
M60A3Driver
Default Re: Will not accelerate fast and has a sputter
Originally Posted by Papa-Ace1100
I have the 2005 limited roadster 3.2L V6 crossfire. I just replaced the serpentine belt and 90% of the fuses in the engine fuse box but, I went to drive it and it starts up fine and runs and drives for about a minute. Then it starts to sputter and my acceleration drops to about 10% of its normal acceleration. It has a full tank of the same 93 premium gas I always put in it. I’m just not sure what/if I need to replace anything?
If you have a code reader see if you're getting any codes. Also check all of those fuses and make sure they are in tight. Also, if you have a volt meter, check to make sure the fuses are good. Just because they are new doesn't mean they're good.
