M60A3Driver
If you have a code reader see if you're getting any codes. Also check all of those fuses and make sure they are in tight. Also, if you have a volt meter, check to make sure the fuses are good. Just because they are new doesn't mean they're good.
Thank you. The fuses were checked as I put them in and I tested them again when I got home and they are all still good. I will have to get a code reader tomorrow and will check again and will reply then. I forgot to mention that this same problem happened to me about 6-6 1/2 months ago. When it happened I pulled over turned it off for about 10 minutes and back on and it seemed to fix itself. I should have know it was going to happen again inevitably but I just left that problem in the past. And have had others to fix since then but now this one it top priority lol.
