Old Nov 12, 2023 | 03:59 PM
mikemadeit94's Avatar
mikemadeit94
Default Re: Error code 52 and will not start
Originally Posted by klong
First time I’ve ever had a problem with my 05 SRT6 in the 14 years that I’ve owned it; drove it to NC (from NE GA - about 6.5 hours each way), and an error code of 52 popped up on the way home.
Went to start it today to look into a light out and no go - car will not turn over. Everything comes on, battery voltage is good (replaced last year), etc. Tried starting it in Neutral and still no go.
Any suggestions?
TIA,
KevinL
Not sure what error code 52 means, but a super common issue is RCM related. There's multiple threads on how to repair it, its usually 3 bad solder joints, also when you're in there make sure your relays are clean and not sticking (youll see burnt residue if they are just carefully disassemble and sand down.
