mikemadeit94
Thanks for the reply, yes the codes where wiped after the first set of pictures I’m not concerned with anything other then BAS/ESP system atp. The second set of pictures is the current codes it’s throwing. Im not concerned about the YAW sensor I can pull one from the local junkyard for $40, im more so asking how to trouble shoot the SLA someone suggested above but I can’t find it in the service manual. I don’t want to throw 300$ at a used SLA if that’s not the issue.
Is your car not shifting or does the dash only have a black square or is in limp mode? The SLA is as low as 149 on eBay and even lower if you found one at a salvage yard. The Yaw sensor is different for a 2005-2008 Crossfire. The 2004 is exactly as a 2004 Mercedes SLK 320.
