Old Nov 14, 2023 | 05:09 PM
onehundred80
Default Re: Valve Cover Fastener Torque
Originally Posted by BarbarianCBX
Sustained an oil leak from passenger side valve cover. Bought new elastomer Gaskets and bolts from Needswings.
1. What are the torque values for the two different length fasteners?
2. Is it necessary to replace the Gaskets on top covers if they are not leaking?
3. Is there a torque sequence ( tightening sequence and torque increments)?
TIA
The two different length screw’s you are talking about I believe are the ones for the valve cover, these should have the same torque on them. The short aluminum screws are torqued to a different setting. They say they should only be used once. Some people are replacing them with stainless steel screws, I would not do that myself but each to their own.
Aluminum and stainless steel are at opposite ends of the galvanic scale so will attack one another strongly in a moist atmosphere, like sea air especially.
I already have my aluminum screws ready on the shelf just in case I need them. 🤞
You should download the Service Manual from the ‘TSB and How To ‘ forum on this site, it has all your answers in it. It is in the ‘Documentation’ sticky.
