Ronman
Is your car not shifting or does the dash only have a black square or is in limp mode? The SLA is as low as 149 on eBay and even lower if you found one at a salvage yard. The Yaw sensor is different for a 2005-2008 Crossfire. The 2004 is exactly as a 2004 Mercedes SLK 320.
Shifting normal just did a transmission service and flush at 55k, no limp mode. Luckily the crossfire in the local junk yard is the same year but I think its the base because of mesh seats. Hopefully that YAW sensor will be fine at this point I guess I'll just do some more research and try to confirm its the SLA.
