drluccia
Installed a touch screen so I can run Car Play like a modern car. It has an option to connect using FM radio and that's what turned out to work best. Much better sound! For the first time I heard and felt sound from the subwoofers. Navigation and music are just a touch away now. I used the window mount to locate the 9 inch screen directly over the center vents. My view is unobstructed and since I use Car Play is our Malibu I can operate the system with a minimum of distraction.
Found it on Amazon, link is below.
https://www.amazon.com/Skisea-Naviga.../dp/B0CJR2G5M1
when you have a moment, please upload a few images post installation. What did you need to modify to get it to work, how did you attach it. Are there external cables? If yes, how are ther concealed. This could be a good solution for many wanting 2023 Audio, sat and video accessibility
