Re: Central locking vacuum pump not working with key
Yes, I replaced both batteries and can see the light flash inside the key when I press it. I'm going to inspect the harness connections on the vacuum pump and try spraying some contact cleaner in there this weekend. If that doesn't do it, I don't know what to do except buy a new/used vacuum pump and swap it in. I've had the Crossfire coupe for over 10 years.
Thanks,
