Old Nov 25, 2023 | 12:38 PM
onehundred80
Default Re: Bad Head Gasket or PCV issue?
Originally Posted by zip439
Run a dip stick down the transmission tube ( you may need to break the seal) and look at the trans fluid. Maybe you will get an indication there of trouble? And Yes, you would need to replace the radiator should that turn out to be your problem.
There is a way to remove the seal without breaking it. I'll look for it.
TIP: The one time use cap that covers the trans fill tube CAN be use over and over again. The trick is to snap off the rectangular piece on the top of the cap and then use a small screwdriver or whatever and push the remaining part of the “lock” down through the cap. Keep the “lock” part, yer gonna reuse it.
Courtesy of Tighed One
