Old Nov 27, 2023 | 01:38 PM
onehundred80
Default Re: Need help with factory radio
Originally Posted by DeKalb
Kenwood Marine radio will give you AM/FM/CD and Blue Tooth, you can answer your phone and there are inputs for other options ... the marine radio has a silver face that matches the console color very well ... model number is KMR-D382BT ... it is a single DIN unit that fits the factory opening ... get the wire harness cable with it and everything will hook to the Crossfire's wiring, only a few connections need to be made by the installer ... if the coupe has sub-woofers use the subwoofer and front locations on the back of the Kenwood unit for the speakers ... I paid just under $200 for the radio and everything I needed with it ... installation was easy
Here is a How To in a PDF, gives all you need to do a good job. You can buy the radio of your choice, this is for a Kenwood.
