Re: Are all flex disc's the same?
with the drive shaft out,, take one of the flexdisk and put it onto the drive shaft ,,, you may have to tap each metal insert ,,, if it goes in all the way flush u r ok,, if you have hammer it on, they are not a good disk
when removing ,, you may need a crow bar or pench bar and pry them off. this is normal jim
