Climate control **** alignment
I removed the climate control assembly to troubleshoot and replace, and turned the heat selection dial by mistake that turns two shafts that the climate control assy
engages with reinstalled. How do I realign the shafts property so that when the dial indicates where the air is going , that it is aligned properly?
Bruce
MODERATOR NOTE: If you are re-installing your climate control module and cannot get it to go back in, see post 4!
