Old Dec 1, 2023 | 04:23 PM
onehundred80
Default Re: Climate control **** alignment
Originally Posted by Bcfichter
I removed the climate control assembly to troubleshoot and replace, and turned the heat selection dial by mistake that turns two shafts that the climate control assy
engages with reinstalled. How do I realign the shafts property so that when the dial indicates where the air is going , that it is aligned properly?
Bruce
Turn the square spindles that stick out from the firewall and set them the middle click position. Then turn the ***** so that they are vertical. Then slide them together which is easier said than done. You well see that one of the square shafts is longer than the other, slide that one on first. It is a tricky job though keeping the square spindles in position.
Good luck.
