Replacing power steering hoses
If you have a crossfire know that you will have to make your own repairs sooner or later.
1.Remove radiator fan.
2.Then remove serpentine belt.
3.As you take the belt off there is a place on the tensioner where you put in a pin in so you can lock it so you can get to both bolts then remove belt tensioner.
4. Remove power steering reservoir
5. Remove power steering hose. From pump. Plug open hole with tape or a small plastic bag and a rubber band to keep dirt out.
6. You can't get to the high pressure and low pressure hose from the top bottom or from the back. The only way is from the front after removing all that I stated to remove.
Part one phase.
