Old Jan 17, 2024 | 06:23 PM
jedavin2209's Avatar
jedavin2209
Default Newbie - repair cost question
Hi everyone
total newbie here with a new to me 05 crossfire srt6.
found out the following needs to be fixed for $5700 or so. Is that reasonable?
includes an oil change 😎
-Valve cover gasket: Heavy oil leak
-Washer reservoir: cracked, the tech will test the pump after the reservoir is replaced.
-Brake flush: Fluid is very dirty
-Belt: Cracked
-Engine rear crank seal: Moderate oil leak
-Engine and transmission mounts: Collapsed causing a vibration.
