Old Jan 17, 2024 | 07:28 PM
M60A3Driver
Default Re: Newbie - repair cost question
Originally Posted by jedavin2209
Hi everyone
total newbie here with a new to me 05 crossfire srt6.
found out the following needs to be fixed for $5700 or so. Is that reasonable?
includes an oil change 😎
-Valve cover gasket: Heavy oil leak
-Washer reservoir: cracked, the tech will test the pump after the reservoir is replaced.
-Brake flush: Fluid is very dirty
-Belt: Cracked
-Engine rear crank seal: Moderate oil leak
-Engine and transmission mounts: Collapsed causing a vibration.
Congratulations on your new to you SRT-6!
If you're reasonably good with your hands you can do more than half of that list yourself. I hope that you're not taking it to a dealership. They will rip you off bad!
If you're not able to do any work yourself, find an independent mechanic who specializes in Mercedes-Benz. Your car is based on the Mercedes-Benz SLK 32 AMG.
There's all kinds of "how to's" on this site, videos on youtube, etc... I hope this was helpful.
Here are some links:
https://www.crossfireforum.org/forum/tsbs-how-articles/
https://www.crossfireforum.org/forum...tech-help.html
https://howtune.com/search?s=chrysler+crossfire
