Old Feb 5, 2024 | 05:27 PM
CyberCG's Avatar
CyberCG
Default No Wipers. No Turn Signals. No Entry using Remote
Hi guys and gals. I need your help.
Symptoms:
* Opened driver door using Remote.
* Started car. No problem.
* Wipers do not work. Turn Signals do not work.
* Exited car. Remote would not lock or unlock car but would flash the tail and front lights when pressed.
What I've done:
* Disconnected battery and connected positive and negative cables. Right after that, the car totally ignores the remote. Tried to resync the remote to the car, but no success.
* Tested and cleaned all fuses in the light switch and in the Underhood driver side fuse boxes.
* Manually tripped the trunk thru the left license plate light hole to get trunk open.
* Checked the Central Lock module in the trunk for water damage. It was completely dry. So was the trunk. Reseated all connectors.
Now what? If you can point me in a direction of next steps to take I will greatly appreciate it.
