Old Feb 5, 2024 | 08:28 PM
GannyX's Avatar
GannyX
Default re: Backup from SRT-6
DCAI SYFI'S DIY
EASY DIY TO GET YOUR CAR TO BREATHE
If you are looking to get your car to breathe more air and cooler air, then it is time to upgrade to a DCAI, meaning Dual Cold Air Intake. See more information on why this could be good for your car [[url=https://web.archive.org/web/20220602091138/http://srt-6.com/knowledge/index.html]HERE]. This modification, eg. a Needswings DCAI can swiftly and easily be purchased from www.crossfiremarket.com [[url=https://web.archive.org/web/20220602091138/http://crossfiremarket.com/3-vendor-parts/needswings/srt-6/intake/needswings-srt6-crossfire-dual-cold-air-intake-system-dcai_i26]HERE], but if you like, there are DIYs and step by step instructions made in order to purchase parts and build your own DCAI. Thanks goes out to Mike S. aka SYFI for making this. See below for the instructions.
PARTS NEEDED
  • 2 x Treadstone Aluminum Piping (AP30070)
Aluminum Pipe
70 Degree Elbow
Diameter: 3.00"
Leg 1: 3" long
Leg 2: 8" long
M.S.R.P. $28.67 ea. (You’ll need 2 ea.)
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.treadstoneperformance.com/product.phtml?p=69156&cat_key=3285&prodname=3%20%2 2+Treadstone+70+Degree+Aluminum+++Piping]HERE]
  • 2 x Spectre 9833
3” dia. Inlet Inline Airbox (includes K&N type cone filter)
M.S.R.P. $79.99 ea.
More info on part can be seen [[url=https://web.archive.org/web/20220602091138/http://www.spectreperformance.com/search/product.aspx?prod=9833]HERE]
PRICE: $51.00 ea. @ Amazon (You’ll need 2 ea.)
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.amazon.com/Spectre-9833-Inline-Air-Body/dp/B005N6WXYM]HERE]
  • 2 x 3" dia. Silicone 1' Straight Hose,
Blue SIL000192 - Genuine 4-ply Silicone
Retail Price: $69.99 You Save $40.00 (57%)
PRICE: $29.99 ea. (You’ll need 2 ea.)
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.siliconeintakes.com/silicone-hose/silicone-tubing-p-192.html]HERE]
  • 2 x 3" dia. X 3” lgth. Silicone Straight Coupler,
Blue SIL000604 - Genuine 4-ply Silicone
Retail Price: $19.99 You Save $13.00 (65%)
PRICE: $6.99 (You’ll need 2 ea.)
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.siliconeintakes.com/silicone-hose/silicone-coupler-p-604.html]HERE]
  • 6 x T-Bolt Clamp for 3" dia. Silicone Parts,
CLA000104 by Silicone Intake Systems
Retail Price: $4.99 You Save $2.39 (48%)
PRICE: $2.60 ea. (You’ll need at least 6 clamps)
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.siliconeintakes.com/t-bolt-clamp/t-band-clamp-p-104.html]HERE]
  • 1 x “Y”-pipe with hoses off a Mercedes SL55.
(the part inside the red oval) MB Part # 1130900129.
Found used in salvage yard for $75. Your cost may vary. Try to find one that has both clips on the Y pipe intact. They simply snap & secure the Y pipe onto the Throttle Body (No screws or pipe clamps needed). The “Y” pipe also has the nipple for connecting the PCV Valve breather line.
PRICE: $91.50
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.oediscountparts.com/parts/index.cfm?searchText=1130900129&make=MercedesBenz& action=oePartSearch&siteid=215242]HERE]
  • 2 x Allstar Performance Brake Ducts
Great affordable front inlet flow directing “Devil Horns”
Such a tight fit that no clamps were needed!
Allstar Performance #049-ALL42141
Brake Duct, Offset Single Hole, 5” x 9-3/4”, 3” OD Inlet, Plastic
PRICE: $18.99 ea. (You’ll need 2 ea.)
Part can be bought [[url=https://web.archive.org/web/20220602091138/http://www.jegs.com/i/Allstar+Performance/049/ALL42141/10002/-1]HERE]
INSTRUCTIONS
You’ll need to remove the plastic pass-throughs from the OEM intakes that are next to the radiator on both sides. A real PITA to remove but can be done to keep them intact incase you want to go back to stock later on. I ended up snapping both of mine off (got impatient and frustrated) so mine will be staying this way. The driver’s side opening is smaller (like around 2.5” – 2.75” ) so the 3” tube will deform into a “D” shape going through the opening. I used a single T-bolt clamp where the 70 Deg. Tube butts up to the filter box tube. Just made sure it aligned right over the joint where they meet inside the couplers. All told, average price is under $300 depending on where the parts are procured. All parts shown are what I used for my particular setup. The silicon tubing is also available in black and red. You may also find other sites that carry other colors, like yellow and green. Just make sure that it’s at least 3 layers, The more layers, the harder it is to collapse. Also I had to trim the outer flange all the way back to the rectangular opening on the brake ducts to make them fit right.
DOWNLOADABLE DOCUMENTS
SOURCES
Mike S. aka SYFI
