Old Feb 6, 2024 | 10:31 AM
DTMenace's Avatar
DTMenace
Default Re: No Wipers. No Turn Signals. No Entry using Remote
Originally Posted by CyberCG
Not a Branded car.
The reset procedure which is quite effective on Porsche is to remove the ground cable from the battery and touch it to the positive terminal for about 30 seconds. The battery is out of the circuit at this point.
The point in this is to allow all the capacitirs in the control modules to discharge. Basically a reset of all modules. It can fix many a weird problem.
CyberCG
The RESET procedure on the Crossfire is to disconnect the negative battery cable (ONLY) for about 30 minutes, Then reconnect and that will wipe out any issues that you may have encountered. BTW, how old is your battery? The Crossfire electrical system is sensitive to any variations in voltage, with any reading below 12 volts will result in weird scenarios with the car.
Good Luck....
Dennis
DTMenace
