Old Feb 7, 2024 | 06:23 AM
CyberCG's Avatar
CyberCG
Default Re: No Wipers. No Turn Signals. No Entry using Remote
I cleaned the CLP pins with spray contact cleaner and a tooth brush. No bent pins. No notable corrosion.
Unlocking the driver door with the key only unlocks the driver door. Same when locking. The console Lock/Unlock switch does nothing now. It worked prior to this problem.
I don't hear any type of noise from the CLP.
Using the remote does not flash the lights since I performed the Battery Reset procedure. It did prior.
But, the car will start right up and can be driven so the Skreem recognizes the FOB RF chip, but the FOB registration may have been lost with the Battery Reset.
