Old Feb 7, 2024 | 09:16 PM
red_2005_convertible's Avatar
Default Re: No Wipers. No Turn Signals. No Entry using Remote
Hi CyberCG,
If what Pizzaguy says is true, that all CLP's are the same, then the CAN bus pins on the 2005 and 2006 are the same. The wire harness colors might be different. If you back probe the connector, you should read 60 ohms if everything is fine (meaning the wiring is fine). If you disconnect the connector from the CLP to probe it from the front, it should read 120 ohms. Did you ever probe pins 2 and 4 to see if they were getting power?
-Jerry
