Re: New trunk Lights
The coupe has one light on the drivers side, and as it has no reflector behind the bulb half of the light is lost behind the panel.
I found that the LED licence plate light unit replaces it perfectly, just remove the original one, switch the connector and put it in the original hole. I added one on the opposite side for extra light.
I also added one in each footwell, so no fumbling for something you dropped at night, it is wired into the map light circuit. The bulb for the map light is also LED, these bulbs have the light directly facing the lens not sideways.
The LED footwell and trunk light mods can be found as .pdf files in my signature file.
