Need specs on machine screws holding latch mechanism in door.
Need specs on machine screws holding latch mechanism in doors. Diameter, thread, length, head.
Assume these are the same on all Crossfires, but ours is a 2005 Crossfire SRT6 Roadster/Convertible.
Purchased car in November, just discovered that the two screws holding the door latch mechanism in the driver door are missing. Two on the passenger door were loose.
Existing machine screws have torx head, about 5/8" long OA. Will try to match, suspect they are or should be metric.
Not sure whether these remaining two are original, or whether they should be longer, etc.
Any suggestion to keep these in place would be appreciated.
(Quick "fix" was to put one screw in each door. Bring on the screw loose jokes.)
Thanks.
