Old Feb 12, 2024 | 02:10 PM
Romad's Avatar
Romad
Default Re: Left turn signal dash light
The hardest thing, for me, is if it's necessary to remove the dash bezel having to remove the panel above the floorboard. At 76 my body just doesn't contort like it used too! It I have to remove the dash "again" I just won't put it back on. All that just to get at two screws if I remember correctly. I did do something to help with bezel removal on my '05 XF which I broke and repaired. At top of the bezel's back side there are two long mounting "teeth" that have to be lifted way up to remove the bezel. Well that's what caused me to break my brittle bezel. I cut off about 1/3 or so of the two "teeth" so it doesn't have to go up so high and stressing the plastic.
