Thread: eletrical issue
Old Feb 20, 2024 | 04:57 PM
DTMenace's Avatar
DTMenace
Default Re: eletrical issue
Originally Posted by dontbreak
have 05 auto low mile car less than 27k owned since Dec 23. car symptoms stalling in gear at stops not all time, car is dead meaning acts like battery is dead sometimes with no lights on dash or anything else also key fob don't do anything when this occurs and no crank or start like dead battery. i have replaced RCM,crank sensor,ground cable still having issues. pulled into work today and notice after shutting off car all power was lost again popped hood and wiggled wire loom going into relay box and notice lights came back on thought this was a ground issue replaced ground wire but obviously its in the wire loom any thoughts on which circuits i should investigate?
dontbreak
Who or where did you buy this Crossfire? A dealer or a private owner? Since you bought this car in December 2023, was it acting like this when you test drove it? Do you have the maintenance history on this 27K miles car?
  1. How old is the battery? Did you check the output, if less than 12 volts, you need a new battery, since the electronics requires at least 14 volts to run the systems. Get a voltmeter and check the output of the battery.
  2. Who told you to change the RCM and a CPS? This type of scenario will empty your wallet quickly, unless you have unlimited funds.
  3. The alarm siren maybe draining your battery, since the internal batteries tend to fail on our cars, since yours is 19 years old.
When you open a thread, we need a little more info from you, to enable a correct diagnosis.
Good Luck
Dennis
​​​​​​​DTMenace
