Old Feb 23, 2024 | 11:22 AM
AnalogRob's Avatar
AnalogRob
Default Top wont open/close - back wont raise high enough
I have an '07 roadster and the place I bought it from said they replaced the fabric top when they got it as it had a busted window and was ripped/cut. The top won't work electronically so I went out today to see if i could do the 'ol up and down reset and the rear part of the top wont raise high enough for the tonneau to open, there was barely enough room for me to get my hands in there with a wrench to unlock it. I'm guessing someone mucked something up but I'm at a loss as to where I should start.
My process so far:
ignition on
windows down
unlock d-ring
lift front a few inches to clear window
open trunk
hex key on the latch
put divider back and close trunk
lift bow (as far as I could)
get wrench on bolt and unlock tonneau
tonneau hits top and cant go any farther
rage
switch light is on solid, when pressed there is a beep.
Any help would be much appreciated
-Rob
