Re: Turn Signals Stopped Working
OK...let's try this...
I'm having an issue you may be able to help me with. I have a 2007 Crossfire Coup, 6 Speed, that has lost its turn signals and hazard flasher. It all started when I got a CD stuck in the CD player. I removed the radio, unplugged the radio and removed the stuck CD. I stupidly did all the without disconnecting the battery. Nothing got shorted, no sparks, no smoke, no harm, no foul. So, I thought. Later when I decided to get back in the car and take it for a spin, I noticed I had no turn signals. I checked the hazard flasher, and it didn't work either. I have checked every fuse in the car with no luck. The Computer Control Relay is new, so I ruled that out. All bulbs are new as well. I mean ALL bulbs. It just seems odd that after the stunt I did with the radio/cd player that I lost my turn signals and hazards. You would think I blew a fuse, but they all check good. I even replaced some that I thought might check good but may not be. I'm lost at this point. Need help.
