Old Feb 29, 2024 | 06:22 AM
GraphiteGhost
Default Re: Turn Signals Stopped Working
Originally Posted by jimi72
OK...let's try this...
I'm having an issue you may be able to help me with. I have a 2007 Crossfire Coup, 6 Speed, that has lost its turn signals and hazard flasher. It all started when I got a CD stuck in the CD player. I removed the radio, unplugged the radio and removed the stuck CD. I stupidly did all the without disconnecting the battery. Nothing got shorted, no sparks, no smoke, no harm, no foul. So, I thought. Later when I decided to get back in the car and take it for a spin, I noticed I had no turn signals. I checked the hazard flasher, and it didn't work either. I have checked every fuse in the car with no luck. The Computer Control Relay is new, so I ruled that out. All bulbs are new as well. I mean ALL bulbs. It just seems odd that after the stunt I did with the radio/cd player that I lost my turn signals and hazards. You would think I blew a fuse, but they all check good. I even replaced some that I thought might check good but may not be. I'm lost at this point. Need help.
I think what pizza means is, when you click the stalk either way, does anything show on the dash where the 'arrows' are (lamp light)? Does the emergency flashers work when the red triangle on the forward console work (lamp in the button, and the two arrows in the dash) light. If working the flashers, do the outside bulbs on fenders in front/rear light? This I believe may locate a bad turn signal stalk. Please check carefully the flashers operation and dash indicators, as asked, and come back here with the results? Good luck!
