Old Mar 5, 2024 | 07:40 AM
xintersecty's Avatar
xintersecty
Default Re: Quick Transmission Question
Originally Posted by racerherbie
Can I change out that connector without having to drain the fluid?
Yes, I just replaced that connector many times with my recent unrelated to the connector transmission issue.
Short procedure:
1) remove the shield
2) twist the lock to unlock the connector.
3) use a socket to loosen the bolt on the inside
4) pull out the connector.
5) use a good connector and make sure all the molding is clean and no left over plastic (buy one from FCP Euro not amazon)
7) make sure you have two O-rings, and replace. This will take some pressure to push in place, the locking tab must be down
8) tighten internal bolt
9) install connector and lock
10) reinstall heat shield
