Old Mar 7, 2024 | 01:08 AM
M60A3Driver
Default Re: Interior door handle not opening door
Originally Posted by paintergman
I know this is an old thread but were you able to solve the issue with the interior door handle ? I’m currently having the same problem. The cable looks to be routed properly it just seems to have lost tension. Can’t tell you how annoying this has become. Any input would be appreciated.
If it's a tension issue, maybe you could put a couple of split washers on the cable near wear it connects to the pull handle to increase the tension. Other than that, you might have to replace that cable. Just a thought.
