Old Mar 10, 2024 | 01:23 AM
M60A3Driver
Default Re: Tonneau latch locks but come switch blinks…until…
Originally Posted by Robgauss
05 Roadster, have been manually raising and lowering the top due to hydraulic issues and a broken tonneau cable.
When the top is raised and the tonneau top latches using the manual tool it is locked, but the conv top switch blinks as if it is not. If I take the tool with the top in place and slip it onto the latch and apply just a little pressure the blinking light goes away…as long as you hold pressure on the tool. If you relax the pressure and remove the tool the blinking light returns.
Have you heard of this one before? Do you think the latch is failing?
No issues at all with bringing the top down and locking it…no blinking light.
I'm just guessing, but it sounds like a contact issue. Maybe a wear spot or dirt on the switch or latch mechanism is not letting it make full contact until you push it past that point with the tool.
