CaptainHero
I went with the K & and filters along with the 74 mm throttlebody upgrade. Our Crossfire has relatively low miles so I wanted to keep it very close to original. The needs wings single cold air intake is probably your best option for performance along with the throttlebody upgrade. On the NA Crossfire the dual Cold air intake does not offer significant gains over the single but comes at a significantly higher cost. From what I’ve read the exhaust systems don’t give a noticeable power improvement but a euro charged tune after the intake and throttlebody upgrades would be beneficial. You could also get the Mercedes V8 airbox which has larger filter elements and more flow volume and get K & N filters for it.
There are three Mercedes filter boxes that fit, only one of them clears the hood liner. They all take the same filters,the original intakes fit inside the Mercedes box, I used the larger Mercedes tubes that came with filter box, they just squeeze into the holes in the rad support.
Frankly the NeedsWings SCI. Is the best option for the NA.
