Old Mar 12, 2024 | 04:02 PM
luxige's Avatar
luxige
Default Re: A slightly different Central Locking issue
The BCM must match the car, the SRT one will not work in an NA, or so Ihave heard.
CLM? What is that?
Have you played around with the fob? Like change the case?
Thanks for your input. I had planned to test drive the SRT (in the event the module swap worked) to see if it would cause limitations. Anyway, swapping the Relay Module and BCM did not help and everything is back as it was.
I did double check for correct battery installation in the fob. If a new case might help I'll try it. The supplied OEM fob is in pretty good shape though.
(CLM - I guess I had modules on the brain when I posted. I meant CLS, System not Module.)
