Re: Engine stalls out every few hours - help!
ONLY a Bosch crank position center will work correctly in the Crossfire. If you bought a generic auto parts store CPS it very well could be your problem.
You should also try disconnecting the electrical connection at the purge valve solenoid. It may throw a code, but see if it stops the stall. Driving with it disconnected will not harm the car for a few days of testing.
