Old Oct 11, 2006 | 03:04 AM
marauderroy's Avatar
marauderroy
Default Re: Oil level madness
I agree, do it yourself. It's easy and you know it's done with the correct oil and filter. I only put 8 qt's of oil in and it shows full. Just put a floor jack on the drivers side, raise it up enough to slide under and remove 2 bolts (near front) to drop the bottom cover and then remove the drain plug on the pass. side of the oil pan.
Be sure to use a fleece oil filter not the paper ones. Some of the dealerships still have the paper ones in stock and will try to sell you that one. BTW Walmart has the best price on Mobile oil unless you find it on sale someplace.
