Old Mar 30, 2024 | 10:14 AM
M60A3Driver
Default Re: Mercedes specific codes
Originally Posted by Esinclair
Hey y'all from Houston, TX.
I got a new code scanner and it goes beyond standard ODBII codes.
I'm learning.
I need to point out, I have no lights on, but I do have a pending ODBII code P0455 Evap System Leak Detected Large Leak Detected.
Do I even need to concern myself with these mercedes specific codes?
P2013
P1174
P1212
P1135
P1134
P1130
P1131
P1132
P1035
Just my 2 cents:
Start with your gas cap, that would be the cheapest cause of a leak. Especially if you have a cheap aftermarket replacement.
Mine caused the gas light to flash and eventually the check engine light came on. One of the codes I got was the same as yours and the other was also Evap leak small. When I put the original back on everything was fine.
