Old Apr 8, 2024 | 12:12 AM
M60A3Driver
Default Re: Urgent help needed Crossfire will not start
Originally Posted by Gary333
Here are my symptoms:
Crossfire will start and then immediately die. When I try starting it again it will not start and it just keeps turning over. I’m getting no fault codes. The car has a new battery. It has both keys and will unlock remotely. Tried a different RCM module from an SLK but the part number ended in 205 rather than 305 . When I tried starting the Crossfire I got nothing and just the electric fan coming on. When I tried my Crossfire RCM in the SLK it had the same symptoms as my Crossfire. Deeply frustrated. Should I buy a new RCM? No one wants to work at it and the local Mercedes specialists said it’s not a Mercedes! I have had trouble free miles up until now. If the RCM would fix it then that would be great but I don’t want to buy it and then discover it could be the SKREEM or something else. Help please!
You can take your RCM apart and hold the fuel pump relay closed with a rubber band.
Somewhere there is a post by tighed1 that explains all of this. Use the search bar in the upper right hand corner.
Here's a video that might help
