Old Apr 17, 2024 | 07:10 AM
dedwards0323
Default Re: Quick Wheel Spacer question
Originally Posted by racerherbie
I am running stock tires up front but wider in the rear (285 35 19) in the rear. My question is would front wheel spacers help the handling. It's a bit "wiggly" when cornering hard. If so would you go with the 10mm or 15mm (needswings.com).
Thanks,
Greg
While I personally don't have your setup on my 2007 Coupe, I do know of several other Crossfire Owners that run the larger tires on the back without reporting any handling issues. Hopefully, one of them will chime in on your thread.
