Old Apr 25, 2024 | 11:55 AM
machfivecrossfire's Avatar
machfivecrossfire
Default Re: Two lonely wires can’t figure out where they go! Help
[QUOTE=Whitexfire84;988942]Hello everyone. I have two wires and I can’t
Wires are coiled up in my hand, but you can see where they lead to on the junction. Please help.
figure out where they go. They come from a junction behind the driver side headlight, and the picture you should be able to see exactly where they’re coming from. It’s two wires one wire is brown with the red stripe and the second wire is a solid brown any help would be greatly appreciated, I have no working horn and I’ve checked the airbag steering wheel connections are tight connections to the horns themselves are tight horns are new and not sure where these two wires lead to and if they may have something to do with my issue, all fuses are fine. RCM needs work , these wires are similar to the wires that to the horns themselves. That’s why I’m not sure if this may have something to do with my issue if someone can verify in their own vehicle where these two wires lead to I’d be greatly appreciative thanks for the input.[/QUOTE
it looks like fog lamp wiring. Horns have 3 wires each. With one solid brown to each horn. I found this one on my parts car. With 2 browns. Raining today I cannot verify without dissasembling a working car. But it is the only wiring with 2 browns together. I cannot actually tell where those two split from the larger part of the harness. A clear pic of that would be helpful for me to identify the location. Also. How far do they reach? Do they make it to the horn? Do they exit the main harness together or from different locations?
