Re: Rcm issues
Thank you sir for your response and help with those codes. Just got to the car a little while ago stranded in a parking lot hooked up a scanner to it and the only code that’s coming up is p0101 for a mass airflow issue when I started the car up it fired up, but the idol is literally all over the place from high to really low. The engine is knocking and pinging. I can hear one of the cold air intake filters, sucking really loud while the other ones not, definitely not drivable. I pulled the MAF sensor harness off the sensor itself while it was running, and there was no change at all. Not sure if that would indicate as I can recall yesterday when the wires were pressed down and the car started running poorly the RCM was getting really really hot , disconnecting the plugs and feeling very hot. Any help would be greatly appreciated. Sorry to be a pain in everybody’s asses, but this just never ends.
