Old May 7, 2024 | 09:31 AM
dick's Avatar
dick
Default Re: 2004 cranks but won't start
Thank you for the quick reply. Ok, car was in storage over winter with battery disconnected. I ran fine when put away. Hook the battery up this spring and engine cranked but would not start. If I sprayed starter fluid in it would fire but die almost immediately. I moved some wires around in the control.module box hoping to see something loose. Then all of a sudden the car would start. Started it several times and drove it probably 20 minutes. Got home turned it off, opened garage door, and when I went to start it, it ran really rough. Then stalled and would not start again.
