[QUOTE=grip grip;578611]I did a lot!
1) I read that the headlight adjustment bolt can break free of the headlight assembly, and there is an easy fix. I applied the fix and I'm now good to go.
2) I installed seat covers.
3) I removed my fan shroud.
4) I used gasket sealant to glue a HID bulb into the headlight housing since the retainer clip is missing.
5) I realized that I have to remove the exhaust, to remove the starter, to install the Miller flywheel lock, to remove the crank pulley.
Hopefully tomorrow I'll have an update of me installing something.
That's what I did today.
[/QUOTE
Any chaNce you know the size to the flywheel bolts??
