M60A3Driver
How old is your battery? When the battery starts to fail it makes the car do weird things.
If you have a battery tender you can try putting it on and let it charge for a day or two. Then remove it and start the car and try to operate the top again. Don't use a high out put charger like a jump starter.
If you don't drive the car often, keep it on a battery tender.
You could also try disconnecting the negative battery cable for about 5 minutes and then reconnect it. I don't know if that will work or not. Just a shot in the dark.
the car is putting out 14.59 amps when running, the battery is only one month old....it does die after a few days sitting,so I will definitely put it on the battery tender...I hadn't thought of that. Thank you for the help.i can hear the pump running and the bow tries to lift but only goes a couple inches.
