Old May 10, 2024 | 02:16 PM
M60A3Driver
Default Re: Convertible top, wing not working
Originally Posted by Lester
the car is putting out 14.59 amps when running, the battery is only one month old....it does die after a few days sitting,so I will definitely put it on the battery tender...I hadn't thought of that. Thank you for the help.i can hear the pump running and the bow tries to lift but only goes a couple inches.
You mentioned that the battery dies after a few days. Do you still have the original alarm siren in the car? That may be the source of your power drain. You can test this by pulling fuse #9 in the engine compartment fuse box near the brake master cylinder.
If the battery doesn't die in a few days, then the alarm is bad and needs to be removed or replaced.
The alarm siren is located under the wiper cowl. It's not a hard job to remove it.
Here's a link to a post I did with pictures and descriptions. If you do take the wiper cowl off, you should clean the drains while you're in there. That's also in my post.
Wiper Cowl Removal, Alarm Removal & Drain Cleaning
Last edited by M60A3Driver; May 10, 2024 at 02:23 PM. Reason: Additional Information
