Old May 10, 2024 | 09:52 PM
Lester's Avatar
Lester
Default Re: Convertible top, wing not working
You mentioned that the battery dies after a few days. Do you still have the original alarm siren in the car? That may be the source of your power drain. You can test this by pulling fuse #9 in the engine compartment fuse box near the brake master cylinder.
If the battery doesn't die in a few days, then the alarm is bad and needs to be removed or replaced.
The alarm siren is located under the wiper cowl. It's not a hard job to remove it.
Here's a link to a post I did with pictures and descriptions. If you do take the wiper cowl off, you should clean the drains while you're in there. That's also in my post.
Wiper Cowl Removal, Alarm Removal & Drain Cleaning
. Thank you for that info. I will definitely check it out on your post, when I bought the car the person put in a new battery, so I’m not sure about the siren, or what that is. The good news is I got the top and spoiler working, the micro switch in tonneau cover was stuck, cleaned it and lubed it up, all working good now….. I’m going to pull #9 fuse tomorrow see if that stops battery from dying.
Thank you Lester
